In a new study of laboratory and satellite data, researchers report a lower value of that energy, known as total solar irradiance, than previously measured, and demonstrates that the satellite instrument that made the measurement, which has a new optical design and was calibrated in a new way, has significantly improved the accuracy and consistency of such measurements.
The new findings give confidence, the researchers say, that newer satellites expected to launch starting early this year will measure total solar irradiance with adequate repeatability to help resolve the long-standing question of how significant contributor solar fluctuations are to the rising average global temperature of the planet.
“Improved accuracies and stabilities in the long-term total solar irradiance record mean improved estimates of the Sun’s influence on Earth’s climate,” said Greg Kopp from the Laboratory for Atmospheric and Space Physics (LASP) at the University of Colorado, Boulder.
The new work will help advance scientists’ ability to understand the contribution of natural versus anthropogenic causes of climate change, the scientists said. That’s because the research improves the accuracy of the continuous 32-year record of total solar irradiance (TSI). Energy from the Sun is the primary energy input driving Earth’s climate, which scientific consensus indicates has been warming since the Industrial Revolution.
Judith Lean from the Naval Research Laboratory in Washington, D.C., specializes in the effects of the Sun on climate and space weather. “Scientists estimating Earth’s climate sensitivities need accurate and stable solar irradiance records to know exactly how much warming to attribute to changes in the Sun’s output, versus anthropogenic or other natural forcings,” Lean said.
The LASP-built Total Irradiance Monitor (TIM) instrument on the NASA Solar Radiation and Climate Experiment (SORCE) spacecraft measured the new lower TSI value. Tests at a new calibration facility at LASP verify the lower TSI value. The ground-based calibration facility enables scientists to validate their instruments under on-orbit conditions against a reference standard calibrated by the National Institute of Standards and Technology (NIST). Before the development of the calibration facility, solar irradiance instruments would frequently return different measurements from each other, depending on their calibration. To maintain a long-term record of the Sun’s output through time, scientists had to rely on overlapping measurements that allowed them to intercalibrate among instruments.
“The calibration facility indicates that the TIM is producing the most accurate total solar irradiance results to date, providing a baseline value that allows us to make the entire 32-year record more accurate,” said Kopp. “This baseline value will also help ensure that we can maintain this important climate data record for years into the future, reducing the risks from a potential gap in spacecraft measurements.”
“We are eager to see how this lower irradiance value affects global climate models, which use various parameters to reproduce current climate, incoming solar radiation is a decisive factor,” said Lean. “An improved and extended solar data record will make it easier for us to understand how fluctuations in the Sun’s energy output over time affect temperatures, and how Earth’s climate responds to radiative forcing.”
Lean’s model, which is now adjusted to the new, lower absolute TSI values, reproduces with high fidelity the TSI variations that TIM observes and indicates that solar irradiance levels during the recent prolonged solar minimum period were likely comparable to levels in past solar minima. Using this model, Lean estimates that solar variability produces about 0.18° Fahrenheit (0.1° Celsius) global warming during the 11-year solar cycle, but is likely not the main cause of global warming in the past three decades.
