See Jupiter at its best
The king of planets shines in January.
By | Published: December 31, 2013
Look for Jupiter in the eastern sky during the early evening in January
Look for Jupiter in the eastern sky during the early evening. The giant planet resides in the constellation Gemini the Twins.
Astronomy: Roen Kelly
Jupiter, largest of the planets, reaches maximum brilliance January 5. On that date, it lies at a point astronomers call opposition. As viewed from Earth, Jupiter lies directly opposite the Sun. On the 5th, Jupiter rises at sunset, sets at sunrise, and is visible in the sky all night.
January’s opposition also is the point when the planet lies closest to Earth, so Jupiter shines brightest and appears largest. Furthermore, opposition places a planet at its highest point — due south — at local midnight. When Jupiter is at its highest point, we view it through the least amount of Earth’s atmosphere. The higher a celestial object, the less air we’re looking through and the better the view.
Jupiter December 28, 2013, sequence
This sequence of three images of Jupiter taken December 28, 2013, shows the planet’s rotation in 44 minutes.
Christopher Go
“Jupiter is a great target for beginning observers,” says Astronomy Contributing Editor Mike Reynolds. “You’ll spot its two largest cloud belts, and you can watch the bright moons change positions from night to night.” Jupiter’s four largest satellites, discovered by Galileo in 1610, are easy to see even through small telescopes.
For several months around its opposition date, Jupiter rises in the northeast. It lies in the zodiac constellation Gemini the Twins. Fortunately, that position means Jupiter will appear high in the sky. From latitude 40° north, the planet’s highest altitude will reach 72° above the southern horizon. This altitude goes up 1° for every degree south you travel.
Jupiter is easy to spot — it shines at magnitude –2.7. This means it appears more than three times as bright as the brightest star in the night sky, Sirius, which shines some 40° south of Jupiter.
At this year’s opposition, Jupiter’s apparent size in a telescope reaches 47 arcseconds. (One arcsecond equals 1/3,600 of 1°.) This large apparent size offers great opportunities for viewing cloud features in the jovian atmosphere. Jupiter completes one rotation in less than 10 hours. Around opposition, it remains above the horizon for at least 12 hours, which allows you to view the entire planet during a single night.
Jupiter’s four bright moons are easy targets through small telescopes. Io takes less than two days to orbit Jupiter, so you can see its relative position change in an hour or so. Our line of sight lies in the plane of the moons’ orbits, so we see occultations (when a moon goes behind Jupiter), eclipses (when Jupiter’s shadow falls on a moon), and transits (when a moon passes in front of Jupiter) at various times. Indeed, watching these four satellites provides plenty of action through a telescope to warm January’s chilly nights.
Fun facts
  • Jupiter, the largest planet, could hold 1,266 Earths inside it.
  • The seven other planets combined would constitute only 68 percent of Jupiter’s volume.
  • Jupiter is more than 317 times as massive as Earth.
  • Jupiter spins so rapidly that its polar diameter is only 93 percent of its equatorial diameter.
  • Jupiter is the second most reflective planet (next to Venus). It reflects 52 percent of the sunlight falling on it. By comparison, Earth reflects 37 percent of sunlight back into space.
  • The solar system’s largest satellite is Ganymede, with a diameter of nearly 3,300 miles (5,270km).
StarDome
Expand your knowledge with these tools from Astronomy magazine
