The discovery was made by associate professor Jie Zhang and his graduate student Xin Cheng using images from the NASA Solar Dynamics Observatory (SDO) spacecraft.
Although researchers believed the magnetic rope was the cause of these giant eruptions on the Sun, scientists had previously not been able to prove this phenomenon existed because of how quickly the rope moves.
However, through close examination of images taken by the Atmospheric Imaging Assembly (AIA) telescope on board the SDO, Zhang was able to pinpoint an area of the Sun where a magnetic rope was forming. The AIA telescope suite is able to capture images of the Sun every 10 seconds, 24 hours a day. This unprecedented cadence in time helped the discovery.
“The magnetic rope triggers a solar eruption. Scientists have been debating whether or not this magnetic rope exists before a solar eruption. I believe that the result of this excellent observation helps finally solve this controversial issue,” said Zhang.
A solar storm is a violent eruption from the Sun, sending billions of tons of charged material, also called plasma, into space at a speed of more than 1 million mph (1.6 million km/h). The cloud of plasma carries with it a strong magnetic field. When the magnetized cloud reaches Earth 1 to 3 days later, a huge amount of energy is deposited into the magnetosphere of the Earth.
Normally, Earth’s magnetosphere shields this harmful solar wind and protects the environment. However, a solar storm has the potential to disrupt the shielding effect and produce severe space weather, which can have harmful effects on a wide array of technological systems, including satellite operation, communication and navigation, and electric power grids.
Zhang’s research will help in giving early warning about solar storms and help minimize the damage done by space weather on Earth.
“Understanding the eruption process of these storms will definitely help us better predict them,” said Zhang. “We cannot prevent solar storms, just like we cannot prevent earthquakes or volcanoes. But the development of prediction capacity can help mitigate adverse effects. For instance, satellite operators can power-down key systems to prevent the possible damage to the systems.”
It is widely believed that magnetic fields in the Sun play an essential role in storing energy and powering solar storms. However, the exact form that magnetic field lines take prior to the eruption are highly controversial. Most field lines are semicircular loops with their foot-points rooted on the surface of the Sun. They cannot erupt easily, and in fact, they often play the role of preventing the eruption.
Scientists suspected that the magnetic rope, if it indeed existed, was the phenomenon that powered the eruption. A magnetic rope contains many magnetic field lines wrapping around a center axis and possibly twisting around each other. Because of the twisting, a strong electric current can be carried by the magnetic rope. Theoretically, the electric current could produce a sufficient electromagnetic force to overcome the overlying constraining force from other field lines and power the magnetic rope to move outward.
AIA images now reveal that, before an eruption, there is a long and low-lying channel running through the entire active region, which heats to a temperature as high as 10 million degrees, and slowly rises. When it reaches a critical point, it starts to erupt quickly. It is a feature distinctly different from the surrounding magnetic field lines. This particular hot channel is now believed to be the magnetic rope that scientists have been looking for.
