MAVEN measures Mars’ atmospheric loss
The NASA mission identified the process that helped rob the cold, arid Red Planet of its warm and wet past environment.
By | Published: November 5, 2015 | Last updated on May 18, 2023
  • NASA's MAVEN mission has determined that solar wind stripping of the Martian atmosphere is a significant process, with a current loss rate of approximately 100 grams per second.
  • This atmospheric erosion is exacerbated during solar storms, suggesting a much higher loss rate in the past when solar activity was greater.
  • MAVEN data indicate that atmospheric escape occurs primarily from the tail region (75%) and polar plume (25%) of Mars' atmosphere, driven by solar wind-induced electric fields accelerating ions into space.
  • The significant atmospheric loss via solar wind stripping is considered a key factor in the transition of Mars from a potentially habitable, warmer and wetter environment to its current cold and arid state.
Artist’s rendering of a solar storm hitting Mars and stripping ions from the planet's upper atmosphere.
Artist’s rendering of a solar storm hitting Mars and stripping ions from the planet’s upper atmosphere.
NASA/GSFC
NASA’s Mars Atmosphere and Volatile Evolution (MAVEN) mission has identified the process that appears to have played a key role in the transition of the martian climate from an early warm and wet environment that might have supported surface life to the cold, arid planet Mars is today.
MAVEN data have enabled researchers to determine the rate at which the martian atmosphere currently is losing gas to space via stripping by the solar wind. The findings reveal that the erosion of Mars’ atmosphere increases significantly during solar storms.
“Mars appears to have had a thick atmosphere warm enough to support liquid water, which is a key ingredient and medium for life as we currently know it,” said John Grunsfeld of the NASA Science Mission Directorate in Washington, D.C. “Understanding what happened to the Mars atmosphere will increase our knowledge of the dynamics and evolution of any planetary atmosphere. Learning what can cause changes to a planet’s environment from one that could host microbes at the surface to one that doesn’t is important to know, and it is a key question that is being addressed in NASA’s journey to Mars.”
MAVEN measurements indicate that the solar wind strips away gas at a rate of about 100 grams (equivalent to roughly 1/4 pound) every second. “Like the theft of a few coins from a cash register every day, the loss becomes significant over time,” said Bruce Jakosky from the University of Colorado, Boulder. “We’ve seen that the atmospheric erosion increases significantly during solar storms, so we think the loss rate was much higher billions of years ago when the Sun was young and more active.”
In addition, a series of dramatic solar storms hit Mars’ atmosphere in March 2015, and MAVEN found that the loss was accelerated. The combination of greater loss rates and increased solar storms in the past suggests that loss of atmosphere to space was likely a major process in changing the martian climate.
The solar wind is a stream of particles, mainly protons and electrons, flowing from the Sun’s atmosphere at a speed of about 1 million miles (1.6 million kilometers) per hour. The magnetic field carried by the solar wind as it flows past Mars can generate an electric field, much as a turbine on Earth can be used to generate electricity. This electric field accelerates electrically charged gas atoms, called ions, in Mars’ upper atmosphere and shoots them into space.
MAVEN has been examining how solar wind and ultraviolet light strip gas from the top of the planet’s atmosphere. New results indicate that the loss is experienced in three different regions of the Red Planet: down the “tail,” where the solar wind flows behind Mars, above the martian poles in a “polar plume,” and from an extended cloud of gas surrounding Mars. The science team determined that almost 75 percent of the escaping ions come from the tail region, and nearly 25 percent are from the plume region, with just a minor contribution from the extended cloud.
Created using data from NASA’s Mars Atmosphere and Volatile Evolution (MAVEN) mission, this visualization shows how the solar wind strips ions from the Mars’ upper atmosphere into space. // NASA-GSFC/CU Boulder LASP/University of Iowa
Ancient regions on Mars bear signs of abundant water — such as features resembling valleys carved by rivers and mineral deposits that only form in the presence of liquid water. These features have led scientists to think that billions of years ago the atmosphere of Mars was much denser and warm enough to form rivers, lakes, and perhaps even oceans of liquid water.
Recently, researchers using NASA’s Mars Reconnaissance Orbiter observed the seasonal appearance of hydrated salts indicating briny liquid water on Mars. However, the current martian atmosphere is far too cold and thin to support long-lived or extensive amounts of liquid water on the planet’s surface.
“Solar-wind erosion is an important mechanism for atmospheric loss, and it was important enough to account for significant change in the martian climate,” said Joe Grebowsky from NASA’s Goddard Space Flight Center in Greenbelt, Maryland. “MAVEN also is studying other loss processes, such as loss due to impact of ions or escape of hydrogen atoms, and these will only increase the importance of atmospheric escape.”
The goal of NASA’s MAVEN mission, launched to Mars in November 2013, is to determine how much of the planet’s atmosphere and water have been lost to space. It is the first such mission devoted to understanding how the Sun might have influenced atmospheric changes on the Red Planet. MAVEN has been operating at Mars for just over a year and will complete its primary science mission on November 16.
