Hubble’s first Frontier Field finds thousands of unseen faraway galaxies
The long-exposure image is the deepest picture taken of a cluster of galaxies and also contains images of some of the intrinsically faintest and youngest galaxies ever detected.
By | Published: January 13, 2014 | Last updated on May 18, 2023
galaxy cluster Abell 2744
This long-exposure Hubble Space Telescope image of massive galaxy cluster Abell 2744 is the deepest ever made of any cluster of galaxies. It shows some of the faintest and youngest galaxies ever detected in space. Abell 2744, located in the constellation Sculptor, appears in the foreground of this image. It contains several hundred galaxies as they looked 3.5 billion years ago. The immense gravity in Abell 2744 acts as a gravitational lens to warp space and brighten and magnify images of nearly 3,000 distant background galaxies. The more distant galaxies appear as they did longer than 12 billion years ago, not long after the Big Bang.
NASA/ESA/J. Lotz, M. Mountain, A. Koekemoer, and the HFF Team (STScI)
The first of a set of unprecedented super-deep views of the universe from an ambitious collaborative program called The Frontier Fields is being released.
The long-exposure image taken with NASA’s Hubble Space Telescope is the deepest picture taken of a cluster of galaxies and also contains images of some of the intrinsically faintest and youngest galaxies ever detected.
The target is the massive cluster Abell 2744, which contains several hundred galaxies as they looked 3.5 billion years ago. The immense gravity in this foreground cluster is being used as a “gravitational lens,” which warps space to brighten and magnify images of far more distant background galaxies as they looked over 12 billion years ago, not long after the Big Bang.
“The Frontier Fields is an experiment. Can we use Hubble’s exquisite image quality and Einstein’s theory of general relativity to search for the first galaxies?” asked Matt Mountain from the Space Telescope Science Institute (STScI) in Baltimore, Maryland. “With the other Great Observatories, we are undertaking an ambitious joint program to use galaxy clusters to explore the first billion years of the universe’s history.”
Simultaneous observations of this field are being done with NASA’s two other Great Observatories, the Spitzer Space Telescope and the Chandra X-ray Observatory. The assembly of all this multispectral information is expected to provide new insights into the origin and evolution of galaxies and their accompanying black holes.
The Hubble exposure reveals nearly 3,000 of these background galaxies interleaved with images of hundreds of foreground galaxies in the cluster. The many background galaxies would otherwise be invisible without the boost from gravitational lensing. Their images not only appear brighter, but also smeared, stretched, and duplicated across the field.
Thanks to the gravitational lensing phenomenon, the background galaxies are magnified to appear up to 10 to 20 times larger than they would normally appear. What’s more, the faintest of these highly magnified objects have intrinsic brightness roughly 10 to 20 times fainter than any galaxies ever previously observed.
The Hubble data are immediately being made available to the worldwide astronomy community where teams of researchers will do a detailed study of the visual crazy quilt of intermingled background and cluster galaxies to better understand the stages of galaxy development.
Though the foreground cluster Abell 2744 has been intensively studied as one of the most massive clusters in the universe, the Frontier Fields exposure reveals new details of the cluster population. Hubble sees dwarf galaxies in the cluster as small as 1/1,000 the mass of the Milky Way. At the other end of the size spectrum, Hubble detects the extended light from several monster central cluster galaxies that are as much as 100 times more massive than our Milky Way. Also visible is faint intra-cluster light from stars inside the cluster that have been stripped out of galaxies by gravitational interactions. These new deep images will also help astronomers map out the dark matter in the cluster with unprecedented detail by charting its distorting effects on background light. An unseen form of matter, dark matter makes up the bulk of the mass of the cluster.
As the Abell cluster was being photographed with Hubble’s Wide Field Camera 3, the telescope’s Advanced Camera for Surveys was trained on a nearby parallel field that is 6 arc minutes away from the cluster. In this field, Hubble resolves roughly 10,000 galaxies seen in visible light, most of which are randomly scattered galaxies. The blue galaxies are distant star-forming galaxies seen from up to 8 billion years ago; the handful of larger red galaxies are in the outskirts of the Abell 2744 cluster.
Hubble will again view these two Frontier Fields in May 2014, but Hubble’s visible-light and infrared camera will switch targets. This will allow for both fields to be observed over a full range of colors, from ultraviolet light to near-infrared.
With each new camera installed on Hubble, the space telescope has been used to make successively deeper, groundbreaking views of the universe. To get a better assessment of whether doing more deep field observations was scientifically compelling or urgent, the STScI chartered a “Hubble Deep Field Initiative” working group. The Hubble Frontier Fields initiative grew out of the working group’s high-level discussions at STScI concerning what important forward-looking science Hubble should be doing in upcoming years. Despite several deep field surveys, astronomers realized that a lot was still to be learned about the far universe. Such knowledge would help in planning the observing strategy for the upcoming James Webb Space Telescope.
The astronomers also considered synergies with other observatories, such as Spitzer, Chandra, and the new Atacama Large Millimeter/submillimeter Array. Over the coming years, five more pairs of fields will be imaged. The next scheduled target is the massive cluster MACSJ 0416.1-2403 for which observations are starting this week.
