Transit of Venus wows astronomers worldwide
The European Space Agency’s microsatellite Proba-2 tracked Venus as it moved across the solar disk over a period of nearly seven hours.
By | Published: June 6, 2012 | Last updated on May 18, 2023
Venus transit
Transit of Venus as seen from Canberra, Australia. Credit: Michel Breitfellner and Miguel Perez Ayucar/ESAC
Astronomers around the world looked to the sky last night and this morning to observe Venus as it passed across the face of the Sun for the last time this century. The European Space Agency’s (ESA) Sun-watching space missions also tuned in for the solar spectacular.
ESA’s microsatellite Proba-2, situated in low Earth orbit, tracked Venus as it moved across the solar disk over a period of nearly seven hours. Venus appears to wobble thanks to the slight up-down motion of Proba-2 and the large distance between the satellite and the Sun.
Of particular interest was the moment of first contact when Venus first appeared to touch the limb of the solar disk, resulting in a tiny dip in solar brightness. The dip associated with Venus’ thick atmosphere, even before Venus had fully entered the solar disk, will help exoplanet scientists study the atmospheres of rocky Earth-sized planets outside our solar system.
Another phenomenon observed during the transit included the “black drop” effect — the small black teardrop shape that appears to connect Venus to the limb of the Sun just after it fully enters the solar disk and again later, when it begins to leave the disk.
Astronomers were also keen to capture the aureole, an arc of light seen around the planet’s disk during the first and last minutes of the transit. It was first observed during the transit of 1761 and revealed that Venus has an atmosphere.
ESA’s teams in Svalbard, Norway, enjoyed the transit under the midnight Sun, in between cloudy spells. From ESA’s Space Astronomy Center (ESAC), Michel Breitfellner and Miguel Perez Ayúcar observed the transit using solar and optical telescopes equipped with cameras. An identical set of instruments simultaneously streamed the transit from the other side of the world in Canberra, Australia.
“Despite interruptions from clouds, it was fantastic to observe nearly the full duration of the transit under the midnight Sun in such spectacular surroundings,” said Pérez Ayúcar.
Over the coming weeks, scientists and astronomers from around the world will compare their results with each other and with data collected by space-based observatories, including ESA’s Venus Express.
“We’re looking forward to comparing the ground-based data with that collected by Venus Express during the time of the transit to provide a complete view of Venus’ rapidly changing atmosphere,” said Håkan Svedhem from ESA.
Loading…
var first_count = true;
function addViewCount() {
if (first_count) {
var rUrl = “http://multimedia.esa.int/layout/set/void/dam/add_view/11074”;
obj = YUI().Get.script(rUrl, {}); first_count = false;
jwplayer(“pi_player”).setup({
‘dock’: ‘true’,
‘image’: ‘http://multimedia.esa.int/var/esadam_site/storage/images/videos/2012/06/venus-solar-transit-2012-proba-2-s-journey-across-the-sun/272964-3-eng-GB/Venus-solar-transit-2012-Proba-2-s-journey-across-the-Sun_video_production_full.jpg’,
‘wmode’: ‘transparent’,
‘height’: ‘250’,
‘width’: ‘400’,
‘controlbar’: ‘bottom’,
‘quality’: ‘true’,
‘modes’: [
{ ‘type’: ‘flash’, ‘src’: ‘http://multimedia.esa.int/extension/esadam/design/standard/flash/player.swf’,
‘config’: {
‘file’: ‘mp4:download/public/videos/2012/06/014/1206_014_AR_EN.mp4’,
‘streamer’: ‘rtmp://fms.50E6.edgecastcdn.net/8050E6/multimedia-delivery.esa.int’,
‘provider’: ‘rtmp’
{ ‘type’: ‘html5’,
‘config’: {
‘file’: ‘http://wpc.50E6.edgecastcdn.net/8050E6/mmedia-http/download/public/videos/2012/06/014/1206_014_AR_EN.mp4’,
‘provider’: ‘video’
‘events’: {
‘onPlay’: addViewCount
