Prior to this discovery, all previously detected fast radio bursts (FRBs) have appeared to be one-off events. Because of that, most theories about the origin of these mysterious pulses have involved cataclysmic incidents that destroy their source — a star exploding in a supernova, for example, or a neutron star collapsing into a black hole. The new finding, however, shows that at least some FRBs have other origins.
FRBs, which last just a few thousandths of a second, have puzzled scientists since they were first reported nearly a decade ago. Despite extensive follow-up efforts, astronomers until now have searched in vain for repeat bursts.
That changed last November 5 when Paul Scholz from McGill University was sifting through results from observations performed with the Arecibo radio telescope in Puerto Rico — the world’s largest radio telescope. The new data, gathered in May and June and run through a supercomputer at the McGill High Performance Computing Center, showed several bursts with properties consistent with those of an FRB detected in 2012.
The repeat signals were surprising — and “very exciting,” Scholz said. “I knew immediately that the discovery would be extremely important in the study of FRBs.” As his office mates gathered around his computer screen, Scholz pored over the remaining output from specialized software used to search for pulsars and radio bursts. He found that there were a total of 10 new bursts.
The finding suggests that these bursts must have come from a very exotic object, such as a rotating neutron star having unprecedented power that enables the emission of extremely bright pulses, the researchers said. It is also possible that the finding represents the first discovery of a sub-class of the cosmic fast-radio-burst population.
“Not only did these bursts repeat, but their brightness and spectra also differ from those of other FRBs,” said Laura Spitler from the Max Planck Institute for Radio Astronomy in Bonn, Germany.
Scientists believe that these and other radio bursts originate from distant galaxies, based on the measurement of an effect known as plasma dispersion. Pulses that travel through the cosmos are distinguished from man-made interference by the influence of interstellar electrons, which cause radio waves to travel more slowly at lower radio frequencies. The 10 newly discovered bursts, like the one detected in 2012, have three times the maximum dispersion measure that would be expected from a source within the Milky Way.
Intriguingly, the most likely implication of the new Arecibo finding — that the repeating FRB originates from a young extragalactic neutron star — is at odds with the results of a study published last week by another research team. That paper suggested FRBs are related to cataclysmic events, such as short gamma-ray bursts, which can’t generate repeat events. “However, the apparent conflict between the studies could be resolved if it turns out that there are at least two kinds of FRB sources,” said Victoria Kaspi from McGill, a senior member of the international team that conducted the Arecibo study.
In future research, the team hopes to identify the galaxy where the radio bursts originated. To do so, they will need to detect bursts using radio telescopes with far more resolving power than Arecibo, a National Science Foundation-sponsored facility with a dish that spans 305 meters and covers about 20 acres. Using a technique called interferometry, performed with radio telescope arrays spread over large geographical distances, the astronomers may be able to achieve the needed resolution.
“Once we have precisely localized the repeater’s position on the sky, we will be able to compare observations from optical and X-ray telescopes and see if there is a galaxy there,” said Jason Hessels from the University of Amsterdam and the Netherlands Institute for Radio Astronomy. “Finding the host galaxy of this source is critical to understanding its properties,” he said.
Canada’s CHIME telescope could help unravel the puzzle, said Kaspi. Thanks to the novel design of the soon-to-be completed apparatus, it is expected to be able to detect dozens of fast radio bursts per day, she said. “CHIME will further our quest to understand the origin of this mysterious phenomenon, which has the potential to provide a valuable new probe of the universe.”
