Using the Cosmic Origins Spectrograph, one of the newest instruments on the NASA/ESA Hubble Space Telescope, these researchers measured for the first time the distances to fast-moving clouds of ionized gas previously seen covering a large fraction of the sky. These fast-moving clouds reside in the distant reaches of the Milky Way and contain huge quantities of gas.
The Milky Way would rapidly change its gas into stars if no supply of new matter were available to replenish the gas. Astronomers have hypothesized that the ionized fast-moving gas clouds could be this reservoir of gas, but it was not known if they were interacting with the Milky Way.
“Our findings explain why the Milky Way can keep having star formation,” Lehner said. “Knowing the distances to these clouds tells us where the gaseous fuel is for forming stars over billions of years.”
Gas clouds can be identified and studied because elements in the cloud absorb small amounts of light from a star or other light source as it passes through a cloud on its way to Earth. The characteristic “fingerprint” left in the spectrum allows astronomers to determine the properties of the gas.
Star formation in the Milky Way
Earlier studies of these fast-moving ionized clouds used light from quasars, which are too far away to mark the clouds’ locations. To solve the problem, Lehner and Howk identified 27 stars around the Milky Way whose distances were known and used Hubble to take line-of-sight readings of light coming from them.
Results from the stellar sample showed the ionized clouds largely resided in the Milky Way’s halo. The authors concluded that these flows of ionized gas are within about 1 galactic radius (40,000 light-years) of Earth. The new Hubble observations revealed the presence of ionized gas in half the stellar samples, comparable to the fraction observed toward more distant quasars.
The gas clouds are not uniformly distributed around the galaxy, but rather collected in different areas. They cover only part of our galactic sky, analogous to the partial coverage of the sky on a partly cloudy day on Earth. This research also confirmed models that predicted gas falling into the Milky Way slows as it approaches. Clouds closer to the galaxy seem to have been decelerated and do not move as fast as those farther away, much like a meteorite slowing as it enters Earth’s atmosphere.
“We know now where is the missing fuel for galactic star formation,”
Lehner said. “We now have to learn how it got there.”
