February 20: The Coma Star Cluster shines
Head out after moonset this evening to chase down planetary nebula NGC 3242 in Hydra. Popularly called the Ghost of Jupiter, this ball of softly glowing gas appears roughly as large on the sky as the disk of Jupiter through a telescope, which is how it earned the nickname.
Glowing at magnitude 7.7, NGC 3242 is about 30° high in the south around 11 P.M. local time. The nearest bright star is 4th-magnitude Mu Hydrae, which shines just less than 2° north of the nebula. Once you’re centered on the nebula’s position, you should see a ghostly orb glowing a pale blue — perhaps more reminiscent of Uranus or Neptune, but much larger than either of these planets in the eyepiece. Spanning about 16″ visually through most scopes, see if you can notice how the innermost 10” or so of the nebula are hollower (darker) than the outer regions. An Oxygen-III filter can help enhance the view.
Sunrise: 6:45 A.M.
Sunset: 5:43 P.M.
Moonrise: 8:35 A.M.
Moonset: 10:46 P.M.
Moon Phase: Waxing crescent (24%)
