Mars orbiter completes primary mission
A major finding shows that the action of water on and near the surface of Mars occurred for hundreds of millions of years Provided by the Jet Propulsion Laboratory, Pasadena, California
By | Published: December 12, 2008
Mars Reconnaissance Orbiter
Artist’s concept of the Mars Reconnaissance Orbiter.
NASA/JPL
December 12, 2008
NASA’s Mars Reconnaissance Orbiter (MRO) has completed its primary, 2-year science phase. The spacecraft found signs of a complex martian history of climate change that produced a diversity of past watery environments.
The orbiter returned 73 terabits of science data, more than all earlier Mars missions combined. The spacecraft will build on this record as it continues to examine Mars in unprecedented detail during its next 2-year phase of science operations.
Among the major findings during the primary science phase is the revelation that the action of water on and near the surface of Mars occurred for hundreds of millions of years. This activity was at least regional and possibly global in extent, though possibly intermittent. The spacecraft also observed that signatures of a variety of watery environments, some acidic, some alkaline, increasing the possibility that there are places on Mars that could reveal evidence of past life, if it ever existed.
Since moving into position 186 miles (299 kilometers) above Mars’ surface in October 2006, the orbiter also has conducted 10,000 targeted observation sequences of high-priority areas. It has imaged nearly 40 percent of the planet at a resolution that can reveal house-sized objects in detail and 1 percent in enough detail to see desk-sized features. This survey has covered almost 60 percent of Mars in mineral mapping bands at stadium-size resolution. The orbiter also assembled nearly 700 daily global weather maps, dozens of atmospheric temperature profiles, and hundreds of radar profiles of the subsurface and the interior of the polar caps.
“These observations are now at the level of detail necessary to test hypotheses about when and where water has changed Mars and where future missions will be most productive as they search for habitable regions on Mars,” said Richard Zurek, Mars Reconnaissance Orbiter project scientist at NASA’s Jet Propulsion Laboratory (JPL) in Pasadena, California.
Included in the observations are hundreds of stereo pairs used to make detailed topography maps and classic images in support of other Mars missions. One image showed the Mars rover Opportunity poised on the rim of Victoria Crater and another of NASA’s Phoenix Mars Lander during its descent to the surface. MRO data prompted the Phoenix team to change the spacecraft’s landing site. MRO data is also being used to select the landing location for NASA’s Mars Science Laboratory, which is scheduled for launch in 2011. For 5 months of Phoenix operations on Mars that ended in November, MRO and NASA’s Mars Odyssey orbiter shared the responsibility of relaying commands to the lander and data from Phoenix back to Earth.
The MRO also found repetitive layering in Mars’ permanent polar ice caps. The patterns suggest climate-change cycles continuing to the present. They may record possible effects of cyclical changes in Mars’ tilt and orbit on global sunlight patterns. Recent climate cycles are indicated by radar detection of subsurface icy deposits outside the polar regions, closer to the equator, where near-surface ice is not permanently stable. Other results reveal details of ancient streambeds, atmospheric hazes, and motions of water, along with the ever-changing weather on Mars.
Most observations from the orbiter will be discontinued for a few weeks while the Sun is between Earth and Mars, which will disrupt communications. Later this month, the orbiter will begin a new phase, with science observations continuing as Mars makes another orbit around the Sun, which takes approximately 2 Earth years.
“This spacecraft truly exemplifies the best in capabilities to support science and other martian spacecraft activities,” said Michael Meyer, lead scientist for the Mars Exploration Program at NASA headquarters in Washington. “MRO has exceeded its own goals and our expectations. We look forward to more discoveries as we continue to look at the Red Planet in spectacular detail.”
