For Chesley to define the asteroid’s mass, he first needed to understand its orbit and everything that could affect that orbit, including neighboring celestial bodies and any propulsive force, however minute, the asteroid could generate.
Incorporating extraordinarily precise observations collected by astronomer Michael Nolan at Arecibo Observatory in September 2011, Arecibo and Goldstone radar observations made in 1999 and 2005, and the gravitational effects of the Sun, Moon, planets and other asteroids, Chesley was able to calculate how far the asteroid deviated from its anticipated orbit. He found that 1999 RQ36 had deviated from the mathematical model by about 100 miles (160 kilometers) in the past 12 years. The only logical explanation for this orbital change was that the space rock itself was generating a minute propulsive force known in “space-rock circles” as the Yarkovsky effect.
The Yarkovsky effect is named for the 19th-century Russian engineer who first proposed the idea that a small rocky space object would, over long periods of time, be noticeably nudged in its orbit by the slight push created when it absorbs sunlight and then re-emits that energy as heat. The effect is hard to measure because it’s so infinitesimally small.
“At its peak, when the asteroid is nearest the Sun, the Yarkovsky force on 1999 RQ36 is only about a half ounce — around the weight of three grapes,” said Chesley. “When you’re talking about the force of three grapes pushing something with a mass of millions of tons, it takes a lot of high-precision measurements over a long time to see any orbital changes. Fortunately, the Arecibo Observatory provided a dozen years of great radar data, and we were able to see it.”
Josh Emery from the University of Tennessee, Knoxville, who used NASA’s Spitzer Space Telescope in 2007 to study the space rock’s thermal characteristics, provided the final piece of the puzzle. Emery’s measurements of the infrared emissions from 1999 RQ36 allowed him to derive the object’s temperatures. From there, he was able to determine the degree to which the asteroid is covered by an insulating blanket of fine material, which is a key factor for the Yarkovsky effect.
With the asteroid’s orbit, size, thermal properties, and propulsive force — Yarkovsky effect — understood, Chesley was able to perform the space rock scientist equivalent of solving for “X” and calculate its bulk density.
“While 1999 RQ36 weighs in at about 60 million metric tons, it is about a half kilometer across,” said Chesley. “That means it has about the same density as water, so it’s more than likely a very porous jumble of rocks and dust.”
Asteroid 1999 RQ36 is of particular interest to NASA as it is the target of the agency’s Origins, Spectral Interpretation, Resource Identification, Security, Regolith Explorer (OSIRIS-Rex) mission. Scheduled for launch in 2016, OSIRIS-Rex will visit 1999 RQ36, collect samples from the asteroid, and return them to Earth.
