Rare brown dwarf discovery provides benchmark for future exoplanet research
Researchers have directly imaged a rare type of brown dwarf that can serve as a benchmark for studying objects with masses that lie between stars and planets.
By and | Published: January 21, 2014
Brown dwarf companion
Direct image detection of a rare brown dwarf companion taken at Keck Observatory.
Crepp et al. 2014, ApJ
A team of researchers led by Justin R. Crepp from the University of Notre Dame in South Bend, Indiana, has directly imaged a rare type of brown dwarf that can serve as a benchmark for studying objects with masses that lie between stars and planets.
Initial data came from the TaRgetting bENchmark-objects with Doppler Spectroscopy (TRENDS) high-contrast imaging survey that uses adaptive optics and related technologies to target older, faint objects orbiting nearby stars, and precise measurements were made at the W. M. Keck Observatory on the summit of Mauna Kea, Hawaii. Brown dwarfs emit little light because they do not burn hydrogen and cool rapidly. Crepp said they could provide a link between our understanding of low-mass stars and smaller objects such as planets.
HD 19467 B, a T-dwarf, is a faint companion to a nearby Sun-like star, more than 100,000 times as dim as its host. Its distance is known precisely, and the discovery also enables researchers to place strong constraints on important factors such as its mass, orbit, age, and chemical composition without reference to the spectrum of light received from its surface.
Precise radial velocity measurements were obtained using the HIRES instrument installed on Keck Observatory’s 10-meter, Keck I telescope. The observations, which span 17 years starting from 1996, show a long-term acceleration, indicating that a low-mass companion was “tugging” on the parent star. Follow-up high-contrast imaging observations were then taken in 2012 using the NIRC2 instrument on the Keck II telescope with the adaptive optics system revealing the companion as shown above. Observations were granted through each of the Keck Observatory consortium members, including NASA, the California Institute of Technology, and the University of California.
While scientists understand the light received from stars relatively well, the spectra from planets is complicated and little understood. Understanding brown dwarfs, such as HD 19467 B, could be a step towards a fuller understanding of exoplanets.
“This object is old and cold and will ultimately garner much attention as one of the most well-studied and scrutinized brown dwarfs detected to date,” Crepp said. “With continued follow-up observations, we can use it as a laboratory to test theoretical atmospheric models. Eventually we want to directly image and acquire the spectrum of Earth-like planets. Then, from the spectrum, we should be able to tell what the planet is made out of, what its mass is, radius, age, etc., basically all relevant physical properties.”
