Massive computer simulation detects cause of high-speed electronics in space
This finding could not only solve an astrophysical puzzle, but also might lead to a better ability to predict high-energy electron streams in space that could damage satellites.
By | Published: February 27, 2012
Aurora_040611
Beautiful aurora in Yukon Territory, Canada. Robert Postma
A mysterious phenomenon detected by space probes has finally been explained thanks to a massive computer simulation that was able to precisely align with details of the spacecraft observations. The finding could not only solve an astrophysical puzzle, but also might lead to a better ability to predict high-energy electron streams in space that could damage satellites.
Jan Egedal from the Massachusetts Institute of Technology in Cambridge had initially proposed a theory to explain this large-scale acceleration of electrons in Earth’s magnetotail — a vast and intense magnetic field swept outward from Earth by the solar wind. Until the new data was obtained from the computer simulation, “it used to be people said this was a crazy idea,” Egedal said. Thanks to the new data, “I don’t get that anymore.”
The simulation shows that an active region in Earth’s magnetotail, where “reconnection” events take place in the magnetic field, is roughly 1,000 times larger than had been thought. This means a volume of space energized by these magnetic events is sufficient to explain the large numbers of high-speed electrons detected by a number of spacecraft missions, including the Cluster mission.
Solving the problem required a staggering amount of computer power from one of the world’s most advanced supercomputers at the National Institute for Computational Science at Oak Ridge National Laboratory in Tennessee. The computer, called Kraken, has 112,000 processors working in parallel and consumes as much electricity as a small town. The study used 25,000 of these processors for 11 days to follow the motions of 180 billion simulated particles in space over the course of a magnetic reconnection event, Egedal said. The processing time accumulated gradually, squeezed in during idle time between other tasks. The simulation was performed using a plasma-physics code developed at Los Alamos National Laboratory that rigorously analyzes the evolution of magnetic reconnection.
Egedal explained that as the solar wind stretches Earth’s magnetic-field lines, the field stores energy like a rubber band being stretched. When the parallel field lines suddenly reconnect, they release that energy all at once — like releasing a rubber band. That release of energy is what propels electrons with great energy (tens of thousands of volts) back toward Earth, where they impact the upper atmosphere. This impact is thought, directly or indirectly, to generate the glowing upper-atmosphere plasma called the aurora, producing spectacular displays in the night sky.
What had puzzled physicists is the number of energetic electrons generated in such events. According to theory, it should be impossible to sustain an electric field along the direction of the magnetic field lines because the plasma (electrically charged gas) in the magnetotail should be a near-perfect conductor. But such a field is just what’s needed to accelerate the electrons. And, according to the new simulation, the volume of space where such fields can build up can, in fact, be at least 1,000 times larger than the theorists had thought possible — and thus large enough to explain the observed electrons.
“People have been thinking this region is tiny,” Egedal said. But now, “by analyzing the spacecraft data and doing the simulation, we’ve shown it can be very large, and can accelerate many electrons.” As a result, “for the first time, we can reproduce the features” observed by the Cluster spacecraft.
That could be important because, among other things, “these hot electrons can destroy spacecraft,” Egedal said, which is why both the military and NASA “would like to understand this better.”
Although this analysis was specific to the phenomena in Earth’s magnetotail, Egedal said similar phenomena may be taking place in much bigger regions of magnetized plasma in space — such as in mass ejections that erupt from the Sun’s corona, which occupy regions 10,000 times larger, or even regions surrounding pulsars or other high-energy objects in deep space, which are much larger still. In the future, Egedal hopes to carry out simulations that would apply to the Sun’s coronal mass ejections. “We think we can scale up the simulation” by a hundredfold, he said.
