“This tells a slam-dunk story that water flowed through underground fractures in the rock,” said Steve Squyres from Cornell University in Ithaca, New York. “This stuff is a fairly pure chemical deposit that formed in place right where we see it. That can’t be said for other gypsum seen on Mars or for other water-related minerals Opportunity has found. It’s not uncommon on Earth, but on Mars it’s the kind of thing that makes geologists jump out of their chairs.”
The vein examined most closely by Opportunity is about the width of a human thumb, 16 to 20 inches (40 to 50 centimeters) long, and protrudes slightly higher than the bedrock on either side of it. Observations by the durable rover reveal this vein and others like it within an apron surrounding a segment of the rim of Endeavour Crater. None like it was seen in the 20 miles (33 kilometers) of crater-pocked plains that Opportunity explored for 90 months before it reached Endeavour, nor in the higher ground of the rim.
Last month, researchers used the Microscopic Imager and Alpha Particle X-ray Spectrometer on the rover’s arm and multiple filters of the Panoramic Camera on the rover’s mast to examine the vein, which is informally named “Homestake.” The spectrometer identified plentiful calcium and sulfur, in a ratio pointing to relatively pure calcium sulfate.
Calcium sulfate can exist in many forms, varying by how much water is bound into the minerals’ crystalline structure. The multi-filter data from the camera suggest gypsum, a hydrated calcium sulfate. On Earth, gypsum is used for making drywall and plaster of Paris.
Observations from orbit have detected gypsum on Mars previously. A dune field of windblown gypsum on far northern Mars resembles the glistening gypsum dunes in White Sands National Monument in New Mexico.
“It is a mystery where the gypsum sand on northern Mars comes from,”
said Benton Clark from the Space Science Institute in Boulder, Colorado. “At Homestake, we see the mineral right where it formed. It will be important to see if there are deposits like this in other areas of Mars.”
The Homestake deposit, whether gypsum or another form of calcium sulfate, likely formed from water dissolving calcium out of volcanic rocks. The minerals combined with sulfur either leached from the rocks or introduced as volcanic gas, and was deposited as calcium sulfate into an underground fracture that later became exposed at the surface.
Throughout Opportunity’s long traverse across Mars’ Meridiani Plain, the rover has driven over bedrock composed of magnesium, iron, and calcium sulfate minerals that also indicate a wet environment billions of years ago. The highly concentrated calcium sulfate at Homestake could have been produced in conditions more neutral than the harshly acidic conditions indicated by the other sulfate deposits observed by Opportunity.
“It could have formed in a different type of water environment, one more hospitable for a larger variety of living organisms,” Clark said.
Homestake and similar-looking veins appear in a zone where the sulfate-rich sedimentary bedrock of the plains meets older, volcanic bedrock exposed at the rim of Endeavour. That location may offer a clue about their origin.
“We want to understand why these veins are in the apron but not out on the plains,” said Ray Arvidson from Washington University in St. Louis, Missouri. “The answer may be that rising groundwater coming from the ancient crust moved through material adjacent to Cape York and deposited gypsum because this material would be relatively insoluble compared with either magnesium or iron sulfates.”
