Little telescope spies gigantic galaxy clusters
The WISE mission’s all-sky infrared maps have revealed one distant galaxy cluster and are expected to uncover thousands more.
By | Published: December 10, 2012
Our solar system, with its colorful collection of planets, asteroids, and comets, is a fleck in the grander cosmos. Hundreds of billions of solar systems are thought to reside in the Milky Way Galaxy, which is itself just a drop in a sea of galaxies.
The rarest and largest of galaxy groupings, called galaxy clusters, can be the hardest to find. That’s where NASA’s Wide-field Infrared Survey Explorer (WISE) can help. The mission’s all-sky infrared maps have revealed one distant galaxy cluster and are expected to uncover thousands more.
These massive structures are collections of up to thousands of galaxies bound together by gravity. They were born out of seeds of matter formed in the early universe and grew rapidly by a process called inflation.
“One of the key questions in cosmology is how did the first bumps and wiggles in the distribution of matter in our universe rapidly evolve into the massive structures of galaxies we see today,” said Anthony Gonzalez from the University of Florida in Gainesville. “By uncovering the most massive of galaxy clusters billions of light-years away with WISE, we can test theories of the universe’s early inflation period.”
WISE completed its all-sky survey in 2011, after surveying the entire sky twice at infrared wavelengths. The 16-inch (40 centimeters) telescope ran out of its coolant as expected in 2010, but it went on to complete the second sky scan using two of its four infrared channels, which still functioned without coolant. At that time, the goal of the mission extension was to hunt for more near-Earth asteroids via a project called NEOWISE.
NASA has since funded the WISE team to combine all that data, allowing astronomers to study everything from nearby stars to distant galaxies. These next-generation all-sky images, part of a new project called “AllWISE,” will be significantly more sensitive than those previously released and will be publicly available in late 2013.
Gonzalez and his team plan to use the enhanced WISE data to hunt for more massive galaxy clusters. The first one they spotted, MOO J2342.0+1301, is located more than 7 billion light-years away, or halfway back to the time of the Big Bang. It is hundreds of times more massive than the Milky Way.
By scanning the whole sky with the improved AllWISE data, the team will sleuth out the true monsters of the bunch, clusters as big as thousands of times the mass of the Milky Way, assembled even earlier in the history of the universe.
Galaxy clusters from the first half of the universe’s history are hard to find because they are so far away and because not many had time to assemble by then. What’s more, they are especially hard to see using visible-light telescopes — light that left these faraway structures in visible wavelengths has been stretched into longer infrared wavelengths due to the expansion of space. WISE can hunt some of these rare colossal structures down because it scanned the whole sky in infrared light.
“I had pretty much written off using WISE to find distant galaxy clusters because we had to reduce the telescope diameter to only 16 inches to stay within our cost guidelines, so I am thrilled that we can find them afterall,” said Peter Eisenhardt from NASA’s Jet Propulsion Laboratory in Pasadena, California. “The longer exposures from AllWISE open the door wide to see the most massive structures forming in the distant universe.”
Other projects planned for the enhanced WISE data include the search for nearby hidden cool stars, including those with masses as low as planets. If a large planet or tiny star does exist close to our solar system, an object some call “Tyche,” then WISE’s infrared data may reveal it.
Distant-galaxy-cluster
A galaxy cluster 7.7 billion light-years away has been discovered using infrared data from NASA’s Wide-field Infrared Survey Explorer (WISE). The discovery image is shown in the main panel. The inset shows a deeper, or more sensitive, optical and near-infrared composite constructed using data from the WIYN telescope at Kitt Peak in Arizona and Japan’s Subaru Telescope on Mauna Kea in Hawaii. The red galaxies in the inset image are part of the cluster, while the circles highlight the galaxies seen by WISE that were used to detect the cluster. This galaxy cluster is the first of thousands expected to be discovered with WISE over the entire sky. // Credit: NASA/JPL-Caltech/UCLA/WIYN/Subaru
