This powerful event, now named Gaia14aaa, took place in a distant galaxy some 500 million light-years away and was revealed via a sudden rise in the galaxy’s brightness between two Gaia observations separated by one month.
Gaia, which began its scientific work July 25, repeatedly scans the entire sky, so that each of the roughly 1 billion stars in the final catalog will be examined an average of 70 times over the next five years.
“This kind of repeated survey comes in handy for studying the changeable nature of the sky,” said Simon Hodgkin from the Institute of Astronomy in Cambridge, United Kingdom.
Many astronomical sources are variable: Some exhibit a regular pattern, with a periodically rising and declining brightness, while others may undergo sudden and dramatic changes.
“As Gaia goes back to each patch of the sky over and over, we have a chance to spot thousands of ‘guest stars’ on the celestial tapestry,” said Hodgkin. “These transient sources can be signposts to some of the most powerful phenomena in the universe, like this supernova.”
Hodgkin is part of Gaia’s Science Alert Team, which includes astronomers from the universities of Cambridge, United Kingdom, and Warsaw, Poland, who are combing through the scans in search of unexpected changes.
It did not take long until they found the first “anomaly” in the form of a sudden spike in the light coming from a distant galaxy that was detected August 30. The same galaxy appeared much dimmer when Gaia first looked at it just a month before.
“We immediately thought it might be a supernova, but needed more clues to back up our claim,” said Łukasz Wyrzykowski from the Warsaw University Astronomical Observatory in Poland.
Other powerful cosmic events may resemble a supernova in a distant galaxy, such as outbursts caused by the mass-devouring supermassive black hole at the galaxy center.
However, in Gaia14aaa, the position of the bright spot of light was slightly offset from the galaxy’s core, suggesting that it was unlikely to be related to a central black hole.
So, the astronomers looked for more information in the light of this new source. Besides recording the position and brightness of stars and galaxies, Gaia also splits their light to create a spectrum. In fact, Gaia uses two prisms spanning red and blue wavelength regions to produce a low-resolution spectrum that allows astronomers to seek signatures of the various chemical elements present in the source of that light.
“In the spectrum of this source, we could already see the presence of iron and other elements that are known to be found in supernovae,” said Nadejda Blagorodnova from the Institute of Astronomy in Cambridge.
In addition, the blue part of the spectrum appears significantly brighter than the red part, as expected in a supernova. And not just any supernova: The astronomers already suspected it might be a type Ia supernova — the explosion of a white dwarf locked in a binary system with a companion star.
While other types of supernovae are the explosive demises of massive stars several times more massive than the Sun, type Ia supernovae are the end product of their less massive counterparts.
Low-mass stars, with masses similar to the Sun’s, end their lives gently, puffing up their outer layers and leaving behind a compact white dwarf. Their high density means that white dwarfs can exert an intense gravitational pull on a nearby companion star, accreting mass from it until the white dwarf reaches a critical mass that then sparks a violent explosion.
To confirm the nature of this supernova, the astronomers complemented the Gaia data with more observations from the ground, using the Isaac Newton Telescope (INT) and the robotic Liverpool Telescope on La Palma in the Canary Islands, Spain.
A high-resolution spectrum obtained September 3 with the INT not only confirmed that the explosion corresponds to a type Ia supernova, but also provided an estimate of its distance. This proved that the supernova happened in the galaxy where it was observed.
“This is the first supernova in what we expect to be a long series of discoveries with Gaia,” said Timo Prusti from the European Space Agency.
Supernovae are rare events. Only a couple of these explosions happen every century in a typical galaxy. But they are not so rare over the whole sky if we take into account the hundreds of billions of galaxies that populate the universe.
Astronomers in the Science Alert Team are currently getting acquainted with the data, testing and optimizing their detection software. In a few months, they expect Gaia to discover about three new supernovae every day.
In addition to supernovae, Gaia will discover thousands of transient sources of other kinds — stellar explosions on smaller scales than supernovae, flares from young stars coming to life, outbursts caused by black holes that disrupt and devour a nearby star, and possibly some entirely new phenomena never seen before.
“The sky is ablaze with peculiar sources of light, and we are looking forward to probing plenty of those with Gaia in the coming years,” said Prusti.
