Astronomers find weird, warm spot on an exoplanet
Scientists found that an exoplanet's hot spot is over to the side of the planet instead of directly under the glare of the Sun.Provided by JPL, Pasadena, California
By | Published: October 20, 2010 | Last updated on May 18, 2023
Exoplanet hotspot
NASA’s Spitzer Space Telescope has found that the hottest part of a distant planet, named Upsilon Andromedae b, is not under the glare of its host star as might be expected. Instead, the planet’s hot spot — illustrated here in this artist’s concept in brighter, orange hues — is more than 80° to the side, closer to the dark side of the planet.
JPL/NASA
Observations from NASA’s Spitzer Space Telescope reveal a distant planet with a warm spot in the wrong place.
The gas-giant planet, named Upsilon Andromedae b, orbits tightly around its star, with one face perpetually boiling under the star’s heat. It belongs to a class of planets called hot Jupiters because of their scorching temperatures and large, gaseous constitutions.
One might think the hottest part of these planets would be directly under the Sun-facing side, but previous observations have shown that their hot spots may be shifted slightly away from this point. Astronomers thought that fierce winds might be pushing hot, gaseous material around.
But the new finding may throw this theory into question. Using Spitzer, an infrared observatory, astronomers found that Upsilon Andromedae b’s hot spot is offset by a whopping 80°. Basically, the hot spot is over to the side of the planet instead of directly under the glare of the Sun.
“We really didn’t expect to find a hot spot with such a large offset,” said Ian Crossfield from the Jet Propulsion Laboratory (JPL) in Pasadena, California. “It’s clear that we understand even less about the atmospheric energetics of hot Jupiters than we thought we did.”
The results are part of a growing field of exoplanet atmospheric science, pioneered by Spitzer in 2005, when it became the first telescope to directly detect photons from an exoplanet, or a planet orbiting a star other than our Sun. Since then, Spitzer, along with NASA’s Hubble Space Telescope, has studied the atmospheres of several hot Jupiters, finding water, methane, carbon dioxide, and carbon monoxide.
In the new study, astronomers report observations of Upsilon Andromedae b taken across 5 days in February 2009. This planet whips around its star every 4.6 days, as measured using the “wobble,” or radial velocity technique, with telescopes on the ground. It does not transit, or cross in front of, its star as many other hot Jupiters studied by Spitzer do.
Spitzer measured the total combined light from the star and planet as the planet orbited around. The telescope can’t see the planet directly, but it can detect variations in the total infrared light from the system that arise as the hot side of the planet comes into Earth’s field of view. The hottest part of the planet will give off the most infrared light.
One might think the system would appear brightest when the planet was directly behind the star, thus showing its full Sun-facing side. Likewise, one might think the system would appear darkest when the planet swings around toward Earth, showing its backside. But the system was the brightest when the planet was to the side of the star, with its side facing Earth. This means that the hottest part of the planet is not under its star. It’s sort of like going to the beach at sunset to feel the most heat. The researchers aren’t sure how this could be.
They’ve guessed at some possibilities, including supersonic winds triggering shock waves that heat material up, and star-planet magnetic interactions. But these are just speculation. As more hot Jupiters are examined, astronomers will test new theories.
“This is a very unexpected result,” said Michael Werner from JPL. “Spitzer is showing us that we are a long way from understanding these alien worlds.”
