- PuWe 1 is a very large planetary nebula.
- It's one of the closest planetary nebulae to Earth.
- Its faintness makes it hard to see with small telescopes.
- Astrophotographers with good equipment can image it.
Many faint planetary nebulae went undiscovered for surprisingly long times after Charles Messier and the Herschels stopped cataloguing nebulous objects lying around parts of the sky. It wasn’t until 1980 that two Austrian astronomers, Alois Purgathofer and Ronald Weinberger, found a large, faint planetary nebulae as they searched plates of the Palomar Observatory Sky Survey.
What was designated Purgathofer-Weinberger 1, often abbreviated PuWe 1, lies in western Lynx, near the border with Camelopardalis, and glows faintly at magnitude 11.2. The object’s large size of 20’ means it has a very low surface brightness — in other words, small parts of it appear to be very dim.
PuWe 1 is so large that it is the second largest planetary nebula in our sky. Its low surface brightness makes it virtually impossible to spot visually through backyard telescopes, but of course astroimagers who have substantial equipment can record it.
Purgathofer-Weinberger 1 lies about 1,300 light-years away, making it one of the closest planetary nebulae to us, thus explaining its large apparent size. Check out this object when you have a chance, particularly if you’re an ambitious astrophotographer.
