New light on dark energy
Probing the cosmic web of the universe helps astronomers better understand dark energy and cosmic expansion.Provided by ESO, Garching, Germany
By | Published: February 4, 2008 | Last updated on May 18, 2023
This image is a snapshot from a computer simulation of the formation of large-scale structures in the universe, showing a patch of 100 million light-years and the resulting coherent motions of galaxies flowing towards the highest mass concentration in the centre. The snapshot refers to an epoch about 10 billion years back in time. The color scale represents the mass density, with the highest density regions painted in red and the lowest in black. The tiny yellow lines describe the intensity and direction of the galaxy’s velocities.
Klaus Dolag/VVDS/ESO
February 4, 2008
Astronomers have used ESO’s Very Large Telescope to measure the distribution and motions of thousands of galaxies in the distant universe. This opens fascinating perspectives to better understand what drives the acceleration of the cosmic expansion and sheds new light on the mysterious dark energy that is thought to permeate the universe.
“Explaining why the expansion of the universe is currently accelerating is certainly the most fascinating question in modern cosmology,” says Luigi Guzzo, lead author of a paper in which the new results are presented. “We have been able to show that large surveys that measure the positions and velocities of distant galaxies provide us with a new powerful way to solve this mystery.”
Astronomers made the stunning discovery 10 years ago that the universe is expanding at a faster pace today than it did in the past.
“This implies that one of two very different possibilities must hold true,” explains Enzo Branchini, member of the team. “Either the universe is filled with a mysterious dark energy which produces a repulsive force that fights the gravitational brake from all the matter present in the universe, or, our current theory of gravitation is not correct and needs to be modified, for example by adding extra dimensions to space.”
Current observations of the expansion rate of the universe cannot distinguish between these two options, but the international team of 51 scientists from 24 institutions found a way that could help in tackling this problem. The technique is based on a well-known phenomenon, namely the fact that the apparent motion of distant galaxies results from two effects: the global expansion of the universe that pushes the galaxies away from each other and the gravitational attraction of matter present in the galaxies’ neighborhood that pulls them together, creating the cosmic web of large-scale structures.
This image shows maps of the distribution of galaxies in the VVDS-Wide survey, showing the presence of large-scale structures. The colors indicate the density of galaxies, going from green to blue, the latter being the densest regions. The data have been cut into three cones, from the closest galaxies (bottom) to the farthest. The sample includes galaxies whose light travelled between 1.3 and 8.5 billion years.
ESO
“By measuring the apparent velocities of large samples of galaxies over the last 30 years, astronomers have been able to reconstruct a three-dimensional map of the distribution of galaxies over large volumes of the universe. This map revealed large-scale structures such as clusters of galaxies and filamentary superclusters,” says Olivier Le Fevre, member of the team. “But the measured velocities also contain information about the local motions of galaxies; these introduce small but significant distortions in the reconstructed maps of the universe. We have shown that measuring this distortion at different epochs of the universe’s history is a way to test the nature of dark energy.”
Guzzo and his collaborators have been able to measure this effect by using the VIMOS spectrograph on Melipal, one of the four 8.2-meter telescopes that is part of ESO’s VLT. As part of the VIMOS-VLT Deep Survey (VVDS), spectra of several thousands of galaxies in a 4-square-degree field (or 20 times the size of the full Moon) at epochs corresponding to about half the current age of the universe (about 7 billion years ago) were obtained and analyzed.
“This is the largest field ever covered homogeneously by means of spectroscopy to this depth,” says Le Fevre. “We have now collected more than 13,000 spectra in this field and the total volume sampled by the survey is more than 25 million cubic light-years.”
The astronomers compared their result with that of the 2dFGRS survey that probed the local universe, i.e. measures the distortion at the present time.
Within current uncertainties, the measurement of this effect provides an independent indication of the need for an unknown extra energy ingredient in the ‘cosmic soup’, supporting the simplest form of dark energy, the so-called cosmological constant, introduced originally by Albert Einstein. The large uncertainties do not yet exclude the other scenarios, though.
“We have also shown that by extending our measurements over volumes about ten times larger than the VVDS, this technique should be able to tell us whether cosmic acceleration originates from a dark energy component of exotic origin or requires a modification of the laws of gravity,” says Guzzo.
“VIMOS on the VLT would certainly be a wonderful tool to perform this future survey and help us answer this fundamental question. This strongly encourages scientists to proceed with even more ambitious surveys of the distant Universe,” says Le Fevre.
