May 19: Three in a row
The waxing Moon now passes 3° north of Jupiter at 9 A.M. EDT; in the evening sky our satellite has moved into Cancer the Crab and sits just over 7° east of Jupiter. Like last night, the Moon, Jupiter, and Venus (in western Gemini) still trace out the plane of the ecliptic in the sky.
About 8.5° to the Moon’s upper left (east), in central Cancer, is the lovely open cluster M44. Also called the Beehive Cluster, this grouping of stars can be visible to the naked eye, though it might be a bit of a challenge to view unaided with the Moon nearby. However, the Moon is still only about 25 percent illuminated, so give it a try.
You will definitely spot M44 through binoculars or any telescope. Stretching some 95’ across, it’s a loose, broad grouping that you can even view comfortably in your finder scope. Glowing at magnitude 3.7, this cluster has been known since antiquity and was once called Phatne in Greek and Praesepe in Latin, both meaning “manger.”
Sunrise: 5:41 A.M.
Sunset: 8:13 P.M.
Moonrise: 9:15 A.M.
Moonset: —
Moon Phase: Waxing crescent (25%)
Saturn now dominates the predawn sky and Mars is growing easier to view as it rises slightly earlier each day. Neptune, the most distant planet in the solar system, is also visible before sunrise, although it remains relatively low while the sky is still dark and doesn’t rise out of the horizon haze until closer to sunrise.
By 4:30 A.M. local daylight time on May 21, 1st-magnitude Saturn is 10° high in the eastern sky. It’s the brightest point of light here, outshining any of the stars around it. Magnitude 1.3 Mars is just a tad fainter, but it’s also still very close to the horizon, only about 1.5° high and located to Saturn’s lower left. Try to follow it as the sky brightens — it will rise higher the closer you get to sunrise, but the twilight will begin to wash it out as well. You can opt to view it through a telescope, but make sure to put away your optics at least several minutes before sunrise from your location, which may differ from the time we give below.
Saturn is a better telescopic object — its rings are clearly visible, and you might even glimpse its brightest moon, Titan, far west of the planet in a dark sky before twilight begins. Saturn’s disk is 16” wide, framed by rings stretching about 37” from end to end. Compare this to tiny Mars if you can catch it, whose disk is just 4” across.
