How to make an asteroid using sunlight
Solar radiation packs a punch capable of creating and destroying asteroid families.
By | Published: October 25, 2017 | Last updated on May 18, 2023
mars800x533NASA
Mars’ Trojan asteroids share an orbit with the Red Planet… and most of them probably came from the same parent body.
NASA
Trojan asteroids don’t orbit in the main belt. Instead, they are asteroids that share an orbit with a major planet, such as Jupiter, Earth, or Mars. Now, astronomers have determined that sunlight is responsible for creating and destroying Trojans around Mars, suggesting our star’s radiation could influence asteroids in other places throughout the solar system as well.
The find was unveiled at the Division for Planetary Sciences meeting held by the American Astronomical Society in Provo, Utah, last week. Apostolos Christou of the Armagh Observatory and Planetarium in Northern Ireland and colleagues were intrigued by the odd grouping of Trojans around the planet Mars. When they dug deeper into the asteroids’ possible origins, they realized that eight of Mars’ 10 Trojans all originated from the same parent body, and were “spun off” that parent by the effects of sunlight.
By definition, Trojan asteroids gather at specific points in a planet’s orbit, grouping at the L4 and L5 Lagrange points due to orbital interactions. In practice, what this means is Trojans either lead or trail a planet in its orbit by 60 degrees, sharing the planet’s journey around the Sun but posing no threat of collision with that planet (though Trojans can collide with each other). Mars’ Trojans in particular are puzzling. Of the 10 known, nine trail the planet. Eight of these share orbits so similar that they are assumed to originate from a single parent body — the largest of the group, named Eureka.
Asteroid_Belt.svg
Trojan asteroids share a planet’s orbit, but lead or trail the planet by 60 degrees. Shown here are Jupiter’s Trojans.
NASA
In the main belt, collisions are often responsible for the asteroid families we see. But collisions are typically violent events, while the orbits of Mars’ Trojans indicate a gentler origin. Based on this evidence, Christou’s team believes that solar radiation pressure — that is, the pressure exerted on a body by the energetic photons in sunlight — caused Eureka to spin faster and faster over time. “Eventually there comes a time where all the bits that make up the asteroid cannot stay together and start flying off,” Christou said in a press release. This effect is actually quite well known as the Yarkovsky-O’Keefe-Radzievskii-Paddack effect, or YORP effect, for short.
Mars’ other two Trojans haven’t undergone the same rotational speed-up. One is already rotating fairly chaotically; Christou explained that because the YORP effect is small, the asteroid’s tumbling overpowers and nullifies it. The other Trojan lies close to the orbital zone of stability that keeps Trojans in place; any small bits spun off by the YORP effect would likely go sailing off into unrelated orbits, rather than stick around as fellow Trojans. Thus, sunlight’s effects could not only create, but also destroy or prevent asteroid families from forming.
Learning more about Mars’ Trojans offers two major benefits. First, “These could be resources for trips to Mars,” says Christou. “If they have hydrated minerals then you can exploit those for fuel.” And second, the YORP effect could also impact asteroids near Earth, helping to explain the origin of several near-Earth asteroid pairs and triplets and improving our understanding of the rocky occupants that share the space closest to home.
