NASA’s Wide-field Infrared Survey Explorer eye spies near-Earth asteroid
As WISE circled Earth, it observed the asteroid several times during a 1.5-day period before the object moved beyond its view.Provided by the Jet Propulsion Laboratory, Pasadena, California
By | Published: January 26, 2010 | Last updated on May 18, 2023
WISE first near-Earth asteroid
The red dot at the center of this image is the first near-Earth asteroid discovered by NASA’s Wide-Field Infrared Survey Explorer (WISE).
NASA/JPL-Caltech/UCLA
January 26, 2010
NASA’s Wide-field Infrared Survey Explorer (WISE) spotted its first never-before-seen near-Earth asteroid, the first of hundreds it is expected to find during its mission to map the whole sky in infrared light. There is no danger of the newly discovered asteroid hitting Earth.
WISE discovered the near-Earth object, designated 2010 AB78, January 12. The mission’s sophisticated software picked out the moving object against a background of stationary stars. As WISE circled Earth, scanning the sky above, it observed the asteroid several times during a period of 1.5 days before the object moved beyond its view. Researchers then used the University of Hawaii’s 88-inch (2.2-meter) visible-light telescope near the summit of Mauna Kea to follow up and confirm the discovery.
The asteroid is currently about 98 million miles (158 million kilometers) from Earth. It is estimated to be roughly 0.6 mile (1 kilometer) in diameter and circles the Sun in an elliptical orbit tilted to the plane of our solar system. The object comes as close to the Sun as Earth, but, because of its tilted orbit, it will not pass close to Earth for many centuries. This asteroid does not pose any foreseeable impact threat to Earth, but scientists will continue to monitor it.
Near-Earth objects are asteroids and comets with orbits that pass relatively close to Earth’s path around the Sun. In extremely rare cases of an impact, the objects may cause damage to Earth’s surface. An asteroid about 6 miles (10 kilometers) wide is thought to have plunged into our planet 65 million years ago, triggering a global disaster and killing off the dinosaurs.
Additional asteroid and comet detections will continue to come from WISE. The observations will be automatically sent to the clearinghouse for solar system bodies, the Minor Planet Center in Cambridge, Massachusetts, for comparison against the known catalog of solar system objects. A community of professional and amateur astronomers will provide follow-up observations, establishing firm orbits for the previously unseen objects.
“This is just the beginning,” said Ned Wright, the mission’s principal investigator from UCLA. “We’ve got a fire hose of data pouring down from space.”
On January 14, the WISE mission began its official survey of the entire sky in infrared light, one month after it rocketed into a polar orbit around Earth from Vandenberg Air Force Base in California. By casting a wide net, the mission will catch all sorts of cosmic objects, from asteroids in our own solar system to galaxies billions of light-years away. Its data will serve as a cosmic treasure map, pointing astronomers and telescopes, such as NASA’s Spitzer Space Telescope and the upcoming James Webb Space Telescope, to the most interesting finds.
WISE is expected to find about 100,000 previously unknown asteroids in our main asteroid belt, a rocky ring of debris between the orbits of Mars and Jupiter. It will also spot hundreds of previously unseen near-Earth objects.
By observing infrared light, WISE will reveal the darkest members of the near-Earth object population — those that don’t reflect much visible light. The mission will contribute important information about asteroid and comet sizes. Visible-light estimates of an asteroid’s size can be deceiving, because a small, light-colored space rock can look the same as a big, dark one. In infrared, however, a big dark rock will give off more of a thermal, or infrared glow, and reveal its true size. This size information will give researchers a better estimate of how often Earth can expect potentially devastating impacts.
“We are thrilled to have found our first new near-Earth object,” said Amy Mainzer of NASA’s Jet Propulsion Laboratory in Pasadena, California. Mainzer is the principal investigator of NEOWISE, a program to mine the collected WISE data for new solar system objects. “Many programs are searching for near-Earth objects using visible light, but some asteroids are dark, like pavement, and don’t reflect a lot of sunlight. But like a parking lot, the dark objects heat up and emit infrared light that WISE can see.”
“It is great to receive the first of many anticipated near-Earth object discoveries by the WISE system,” said Don Yeomans, manager of NASA’s Near-Earth Object Program Office at JPL. “Analysis of the WISE data will go a long way toward understanding the true nature of this population.”
