Methane detected on extrasolar planet
Hubble finds the first organic molecule on a planet orbiting another star.Provided by Hubble ESA, Garching, Germany
By | Published: March 19, 2008 | Last updated on May 18, 2023
HD 189733b
Artist’s impression of the extrasolar planet HD 189733b, now known to have methane and water.
ESA/NASA/G. Tinetti (University College London, UK & ESA)
March 19, 2008
The NASA/ESA Hubble Space Telescope has made the first detection ever of an organic molecule in a planet orbiting another star. This breakthrough is an important step in eventually identifying signs of life on a planet outside our solar system.
The telltale signature of the molecule methane in the atmosphere of the Jupiter-sized extrasolar planet HD 189733b has been found with the Hubble Space Telescope. Under the right circumstances methane can play a key role in prebiotic chemistry, the chemical reactions considered necessary to form life as we know it. Although methane has been detected on most of the planets in our solar system, this is the first time any organic molecule has been detected on a world orbiting another star.
This discovery proves that Hubble and upcoming space missions, such as the NASA/ESA/CSA James Webb Space Telescope, can detect organic molecules on planets around other stars by using spectroscopy, which splits light into its components to reveal the fingerprints of various chemicals.
“This is a crucial stepping stone to eventually characterizing prebiotic molecules on planets where life could exist,” says Mark Swain of NASA’s Jet Propulsion Laboratory, who led the team that made the discovery. Swain is lead author of a paper in the March 20 issue of Nature.
HD 189733b
A wide star field image of the region around HD 189733b. The star HD 189733 is located in the center, just to the left of the planetary nebula Messier 27. The field-of-view is approximately 2.7° by 2.8°.
NASA/ESA/Digitized Sky Survey 2
The discovery comes after extensive observations made in May 2007 with Hubble’s Near Infrared Camera and Multi-Object Spectrometer (NICMOS). It also confirms the existence of water molecules in the planet’s atmosphere, a discovery made originally by NASA’s Spitzer Space Telescope in 2007. “With this observation there is no question whether there is water or not. Water is present,” says Swain.
The planet, HD 189733b, now known to have methane and water vapor, is located 63 light-years away in the constellation Vulpecula, the little fox. HD 189733b, a “hot Jupiter”-type extrasolar planet, is so close to its parent star that it takes just over 2 days to complete an orbit. Hot Jupiters are the size of Jupiter but orbit closer to their stars than the tiny innermost planet Mercury in our solar system. HD 189733b’s atmosphere swelters at 900°C, about the same temperature as the melting point of silver.
The observations were made as the planet HD 189733b passed in front of its parent star in what astronomers call a transit. As the light from the star passed briefly through the atmosphere along the edge of the planet, the gases in the atmosphere imprinted their unique signatures on the starlight from the star HD 189733. According to coauthor Giovanna Tinetti from the University College London and the ESA: “Water alone could not explain all the spectral features observed. The additional contribution of methane is necessary to fit the Hubble data.”
HD 189733b
A wide field image of the region of sky in which HD 189733b is located. In this image we can see the asterism of the “Summer Triangle,” a giant triangle in the sky composed of the three bright stars Vega (top left), Altair (lower middle) and Deneb (far left). HD 189733b is orbiting a star very close to the centre of the triangle.
A. Fujii
Methane, composed of carbon and hydrogen, is one of the main components of natural gas, a petroleum product. On Earth, methane is produced by a variety of sources: natural sources such as termites, the oceans and wetland environments, but also from livestock and manmade sources like waste landfills and as a by-product of energy generation. Tinetti is however quick to rule out any biological origin of the methane found on HD 189733b. “The planet’s atmosphere is far too hot for even the hardiest life to survive, at least the kind of life we know from Earth. It’s highly unlikely that cows could survive here!”
The astronomers were surprised to find that the planet has more methane than predicted by conventional models for hot Jupiters. This type of hot planet should have much more carbon monoxide than methane, but HD 189733b doesn’t. Tinetti explains: “A sensible explanation is that the Hubble observations were more sensitive to the dark night side of this planet where the atmosphere is slightly colder and the photochemical mechanisms responsible for methane destruction are less efficient than on the day side.”
Though the star-hugger planet is too hot for life as we know it, “this observation is proof that spectroscopy can eventually be done on a cooler and potentially habitable Earth-sized planet orbiting a dimmer red dwarf-type star,” Swain says. The ultimate goal of studies like these is to identify prebiotic molecules in the atmospheres of planets in the habitable zones around other stars, where temperatures are right for water to remain liquid rather than freeze or evaporate away.
“These measurements are an important step to our ultimate goal of determining the conditions, such as temperature, pressure, winds, clouds, etc., and the chemistry on planets where life could exist. Infrared spectroscopy is really the key to these studies because it is best matched to detecting molecules,” says Swain.
